kfx/z400 wont run.
Old Oct 22, 2004 | 08:39 PM
BeastMan's Avatar
Default kfx/z400 wont run.
When i let the bike set for over 2 weeks it is hard to start, i have to pull start it behind me truck. This is not good but i was told by dealer that it was normal??
Now the big problem. When i get it started it will sputter and when i give it alot of gas it will die out. I was at the local track about 2 weeks ago with no problems, but today when i try to start it this crap happends. I rode it around for a while in 1st gear in my yard but when i get to 2nd it died out, and would not start back.
Anyone have a clue whats up??
Also posted of kawie forum
Old Oct 22, 2004 | 10:11 PM
wrench12123's Avatar
it could be your jetting??? im not sure, that would be my guess
Old Oct 22, 2004 | 10:47 PM
mucky's Avatar
you need to clean your carb out and drain out the gas
sounds like the fuel system is dirty
Old Oct 23, 2004 | 02:26 AM
bulldogz400's Avatar
Try this...put your fuel petcock in the RESERVE position, then fire it up and see what that does for ya.
Old Oct 23, 2004 | 01:38 PM
greenrider86's Avatar
You've got a clogged up carb. Happened to my rancher and my friends eiger. My KFX is always easy to start, no matter how cold it is or how long it has set. My friends eiger and my rancher did exactly as your kfx did. sputtering and stalling when reved higher. Drain some gas through the carb and look for dirt and bubbles in the bottom on the container your draining it in. My friends eiger didnt sputter and act up all the time either. One day it would run fine and the next it would not even hardly run. Dont worry it nots a big problem. Just clean your carb. If necessary you can get a carb rebuild kit too for just about $30 or something like that. Good luck.
Old Oct 23, 2004 | 09:13 PM
BeastMan's Avatar
dang this is going to be my 2nd time to have to clean my carb, anyone know why i would need to be cleaning it so often? i run no air box lid and a k&n. Could this be my problem, the slow and slilent killer K&N? And no i dont ride in the mud.
Old Oct 23, 2004 | 09:27 PM
DID YOU TRY MY SUGGESTION??
Often, it looks like you have fuel in the tank, (which you do), but it is actually in the reserve! Mine did the same thing as yours, wouldn't stay running, couldn't figure it out, but then I put some more gas in the tank, and whala, it was fixed. Don't go doin a big job in carb cleaning when it could be a SIMPLE fix...
Old Oct 23, 2004 | 11:39 PM
BeastMan's Avatar
i can tell when theres fuel in the tank, and i never use resrv.
So fuel is not the problem
gota be the carb
Old Oct 24, 2004 | 12:20 AM
Ok just makin sure...I've seen at least 10 people on here, including myself, who have been stumped only to find out its such an easy fix, AT LEAST 10.
Old Oct 24, 2004 | 12:41 AM
BeastMan's Avatar
lolz nah i gots gas, will tear into carb tomarrow
Bob E.
Oct 1, 2019 09:08 AM
Shainasmash
May 8, 2017 06:38 PM
EIF
Apr 20, 2017 07:15 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
hueby
Aug 29, 2015 08:34 AM
