kfx/z400 clutch setting help and jetting help
Ok when i pull my clutch all the way in it still drags, it does not engage all the way. Were do you set the clutch on this bike?
Also my jetting, i have no air box lid and a K&N with a gutted stock pipe at sea level, what would my mainjet need to be, right now its a 150.
1 more thing. is there an easyer way to get to the jets besides taking the fuel tank off and pulling the carb out?
This is final question, mabey a dumb one but im no mechanic at all, when someone refers to the quad falling out at the high end does that mean when its rapped out in 1st gear or any gear with the rpm high or does it mean it falls out in the higher gears?
The clutch problem can be fixed by adjusting your cableadjustment on your handlebars takes about 1 min. YOur jetting should be around 160 is what i am thinking and when they say falling out on topend , its just wide open throttle for more than a short time.
bpegram84
Jul 22, 2015 08:15 AM
