King Quad ground Clearance
I had seen some one was complaining about the front ground clearance of the King quad.
They had said that the rear was fin but they where only getting 9 inches up front.
I got an email from high lifter and they have replacement springs to lift the front. they say the are the same ase the Brute Force springs.
I do not know how much lift they give I am waiting on the email back.
From High lifter:
The springs don't lift any higher than your OEM stock springs.The difference is your springs begin to sag,loosing about 1" of clearance due to a number of reasons.Ours don't sag and raise you back to factory spec height but will hold you there.Our springs add 33 lbs. capacity to each spring.This stops tires from hitting the fenders and also stops swaying,ducking,diving of the body.The only thing to give you an added inch would be our lift kit when it becomes available.
