Troubles with my LT250R '86
Hey i need some help getting my LT250R running corrrectly. Any help would be much apreciated. My problem is i dont know what my problem is. It runs quite rich and fouls alot of plugs. I have torn apart the carborator and cleaned everything and the main and pilot jet are stock sizes 210 and 45. i have the idle screws at factory settings and i set the needle to the very top notch. It still runs rich and i dont know why. Another problem i am having is getting it to start sometimes. sometimes it starts fine others it wont. I dont know if im not getting correct compression, i know how to check it but i dont know how much it is supposed to have. I dont know if my muffler has anything to do with it. it is stock and the seal between the pipe and the muffler is not very tight. I dont know if that has anything to do with it. Any suggestions or questions for me would be apresiated.
Thanks.
Thanks.
Would the needle jet have anything to do with it. I just dont like the fact that i had to put the needle to the very top setting when its supposed to be in the middle. do i need a new needle jet or a new needle?
I was able to check my compression yesterday and i got a reading of 145. is this enough, or should i put a new piston and ring set in? I probably will put a piston in it anyway but what size is stock or what size would you say is the best? i can always bore it larger if i need to.
Not to be a bother but i have another question. My LT's rear shocks are very soft. I noticed that there is a place to put air in them and tryed to but there is no presure in it and none will go in. is this a problem? how do i make the rear end stiffer? Thanks for all the help.
mrtidy
Feb 3, 2016 05:00 PM
