Z250 Spark arrestor removal?
Old Dec 25, 2004 | 03:37 PM
wannabe1's Avatar
Default Z250 Spark arrestor removal?
OK, I just removed the allen head screw(bolt) that holds the spark arrestor in on new Z250. Now can't figure how to remove the thing, is the whole outer pipe supposed to come off or just the inner sleeve looking portion? I have sprayed the area with some penetrating oil, but nothing wants to turn or pull-out. What the deal?
Old Dec 25, 2004 | 03:52 PM
rolsmojave3's Avatar
yeah yours is like my Eiger i suppose...i have tried everything to get that thing out..but it wouldn't...so i gave up and never thought about it tilll now
Old Dec 25, 2004 | 05:35 PM
wannabe1's Avatar
The manual says remove the bolt, and remove spark arrestor. But I've had strap wrenches, visegrips, etc. on it and it doesn't move or I'm a dumb ___ and doing something wrong, but a spark arrestor should be pretty simple I would think.
Old Dec 25, 2004 | 07:52 PM
flerbinburben's Avatar
The bolt on the bottom of the silencer its a allen you turn that and it should come out.
Old Dec 27, 2004 | 12:25 PM
ElectricShift's Avatar
Mine didnt come out easily either. Just get a wrag and nice pair of pliars and yank it....just the inner sleave comes out.
Old Dec 27, 2004 | 03:13 PM
poopy's Avatar
mine came out pretty easy. i just did what the manual said.
Old Dec 27, 2004 | 03:58 PM
GTFZ250's Avatar
Electric shift has got it---All u have to do is unscrew that little allen wrench bolt with a allen wrench and take a pair of plyers to the little lip and pull it out (may take some force) and make sure u put a peice of cloth or sumthing under the pliers otherwise the paint will come off.
If it still doesnt come out take a rubber mallot and bang on it a bit
Old Dec 27, 2004 | 04:00 PM
GTFZ250's Avatar
Dont turn it! pull straight out if u turn it it will only get jammed in there even worse. Be aggressive![img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 27, 2004 | 04:36 PM
Yeah I fell on my butt the first time I pulled it out you gotta use some force but it will come out.
Old Dec 27, 2004 | 08:46 PM
wannabe1's Avatar
Got R Done, never would have thought it would have taken that much pulling to remove.
Thanks for the aggressive tip. I will probably put it back in or modify it. It did not really increase noise level as much as I thought it would, so maybe it is not all that restrictive. I am still looking for jetting help and will "bump" my post.
