crank threads?
Old Dec 29, 2004 | 06:43 PM
butters's Avatar
Default crank threads?
does anyone know the thread size for the crank, clutch side.. lt500
i need to retap mine but i cant find the size
Old Dec 29, 2004 | 08:54 PM
Semms40oz's Avatar
if you screwed up your thread then using a die of the same size as they were isn't going to help much unless you just messed up the threads at the end of the shaft. If thats the case, sorry i'm not sure on the thread size, if you did screw up all of the thread then just go slightly smaller and pick up the correct size nut.
Old Dec 29, 2004 | 10:03 PM
butters's Avatar
its just the very top of the threads are a little smushed down..... it just needs to be chased and they will be fine
Old Dec 31, 2004 | 12:28 AM
atvbill's Avatar
they make a tool called a thread file, it usually has 4 sides and 2 ends, you just pick the one that fits your thread pitch...unlike a die, you just kinda file the threads back straight
Old Dec 31, 2004 | 03:20 AM
LT2Fiddy's Avatar
i had the same problem on my 250, only every bit of thread was gone off the shaft and the nut also. I found one of those thread files and it took about an hour but finally got it back to new. Saved tons of money and time.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Sassinm1
Sep 30, 2015 04:23 AM
Jackg17
Sep 26, 2015 09:30 PM
