lt500 not starting
Old Jan 3, 2005 | 07:15 PM
newLTkid's Avatar
Default lt500 not starting
i run klotz R50 synthetic at 40:1, the only time i replaced a plug was after i had motor work done.
Old Jan 3, 2005 | 07:58 PM
86LT250RFatty's Avatar
on my LT250R i ran 32:1 but since the 500 is a lowerrevvin engine, u can run 42:1 with no problems if you use a good oil like Golden Spectro Synthetic.
Old Jan 3, 2005 | 08:15 PM
ZillaRider87's Avatar
Originally posted by: gnjeff
they are all ways hard to start. suzuki put in a built in theft system that only the owner knows how to start. it will take some time but he will figure it out.[img]i/expressions/face-icon-small-happy.gif[/img]
lol so true, im the only one that can start my quad, all my friends have tried but couldnt do it.
Old Jan 3, 2005 | 08:16 PM
oh yea, and try giving it a little throttle when kicking it, that helps mine.
Old Jan 4, 2005 | 11:30 AM
  #15
gonetothedunes's Avatar
this is a bad question but how do you tell if it the stock carb, sorry but i do not know too much about them and that is why i am here... thanks
Old Jan 5, 2005 | 12:42 PM
  #16
Duneaddict's Avatar
Go to the dunes: Please keep in mind that when you change oil ratio's, that you WILL need to do some re-jetting. And chances are your jetting being off will typically make it harder to start... Food for thought.
The old days, the mfg recommended 20:1 ratios, but that's with the old dino oil.... the newer synthetics recommend 32:1 and up... Pick your poison, and jet accordingly, and stick with it... that will yield the best results.
Old Jan 5, 2005 | 04:24 PM
  #17
butters's Avatar
the stock carb is a mikuni with a rectanle slide..... i can get model #'s if u need it
Old Jan 5, 2005 | 07:17 PM
  #18
do you have a pic of the carb or know of a site i can visit and, thank you guys for the help
Old Jan 5, 2005 | 07:24 PM
  #19
2StrOkeFReaK's Avatar
Can you see what # is stamped on the left side of the carb?
I remember seeing old post's on most of your questions dude. All you have to do is search.
There is ALOT of good Zilla info on this site, for free!
Freak
Old Jan 6, 2005 | 06:01 AM
  #20
gnjeff's Avatar
http://albaaction.com/ go to this web site look up the factory parts section. pick the make and year of the bike and it will list parts of the bike and give you an exploded view of that part it will help out with finding parts and give you an idea of how much they cost if still are available.
