MY Vinson is a pile of crap
Old Jan 22, 2005 | 05:36 PM
Kegbasher's Avatar
Default Vinson is a pile of crap
My girlfriend has an 04 and the thing just seized up and it is out of warrenty. It ran out of oil due to a faulty genuine suzuki filter.
Now I have to pull out the paper weight of a motor and rebuild it. Is there any performance parts out there for this slouch?
It probably needs a new cam anyways. I don't think it needs to be bored/new piston but if there is a reasonably priced high comp piston we will probably get it.
Old Jan 22, 2005 | 05:49 PM
7QuadSport7's Avatar
Default MY Vinson is a pile of crap
You mean your girlfriends Vinson is a pile of crap[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 22, 2005 | 06:06 PM
VinsonGurl's Avatar
Yea it's my quad and I blew it up! Can't believe there's no oil light or low oil shutoff.....I didn't even know it was losing oil b/c it was all caught in my skid plates! My warranty was up just last month! That was a very expensive ride last weekend! So if we gotta fix it n e ways, we should do it right! But are there performance parts available?
Old Jan 22, 2005 | 06:23 PM
for a vinson, get an exhaust first and then an air filter and a jet kit, that thing should fly all for about 320$
Old Jan 22, 2005 | 06:30 PM
VinsonGurl's Avatar
maybe in the future.....but right now he's only looking for what's needed to fix my motor...and hopefully get some more power out of it....
Old Jan 22, 2005 | 06:53 PM
sliver's Avatar
Phone the suzuki rep for your area and explain what happend and you might get it fixed as a "good will to customer". G.M. fixed my truck this way.
Old Jan 22, 2005 | 07:41 PM
JeffinTD's Avatar
If you can show it was a defective, genuine filter that caused the failure, I would think Suzuki would cover it? At least the parts?
Couldn't hurt to ask.
Old Jan 23, 2005 | 02:28 AM
aksafari's Avatar
Best of luck to you, and God's grace, as I hear Suzuki is a clan of tight fisted bastards when it comes to out of warrany "good will".
Why not 581 kit it? Shouldn't be TOO much more expensive since you'll need a new piston anyway (most likely).
Old Jan 23, 2005 | 10:50 AM
Vinson581's Avatar
here it is the complete info on what it entails
95mm piston 195$
Nikasil Cyclinder sleeve-275$
Cyclinder sleeve installation-150$
Head Gasket-30$
Bore Cases-50$
Cam-150$
Valve springs-95$
Port and Flow cyclinder head-250$
fst 37mm carb kit-250$
it is now 11:1 compression ratio, on 93 octane a must.
in order to install this kit the following must be done
remove old sleeve by boreing
bore case to accomadate larger sleeve
A aftermarket pipe is a must Yoshimura, and HMF are the only ones that accomadate the mass flow of air
K&N filter
Possibley a re-clutching to compensate for the higher rpms of the motor.
The vinson will now be able to do wheel standing wheelies, from a rolling start, or while at a clip. total cost ranges from
1300 for the kit about, to 1600 with clutching and pipe.- a good pipe is a HMF, or a Yoshi, the pipe jet filter, will be about 220$, dont get a jet kit. -0 just go to the dealer, or someware and buy individual jets at 4 dollars a jet, fst should be able to set you up with numbers.
Please contact Mickey Dunlap at FOUR STROKE TECH (FST) for information
v581
btw i always use a FRAM PH6018 oil filter.
Old Jan 23, 2005 | 01:07 PM
Kegbasher's Avatar
Thankyou for your replies. I really have to take it apart to see exactly what it needs and take it from there. I'll let you guys know how it turns out.
