King Quad EFI Failure - cold weather
Old Jan 24, 2005 | 01:24 PM
Sullivad's Avatar
Default King Quad EFI Failure - cold weather
My EFI has been failing when really cold (around -15F) and I was getting the flashing red " F1 " light. Manual says -bring back to the dealer. When I did they could not find it because it would never get that cold, so he showed me how to diagnose the error code.
Basically you stick a wire between 2 contacts on a wiring harness under the seat and the error code shows up on the instrument panel. So when it failed again this weekend it read "C-41".
I experimented by placing a hand warmer hot pack on each electronic component under the seat and finally found one which caused it to work again!
The dealer is looking into which component it is for certain - but in my mind I already know.
Just in case anyone else has seen this.... if so please let me know. thanks
Old Jan 24, 2005 | 06:57 PM
ZigZilla's Avatar
I had this happen to me Last Sat. It was so cold , It took me about 5 minutes to get her started. It finally started up and had no problem the rest of the day.
Old Jan 24, 2005 | 07:03 PM
scottd's Avatar
What's the deal....I thought fuel injection was supposed to be the ANSWER! I'll stick to my carbed BF for now.
Old Jan 24, 2005 | 07:34 PM
tmac2's Avatar
Sullivad,
Don't know if you already know this or not but the service manual states the C41 code is the fuel pump relay.
It's been real cold around here and have not experienced any problems yet myself.
Old Jan 24, 2005 | 09:32 PM
MUDDY4LIFE's Avatar
Its been -30 here in Michigan a few days and the KQ has fired right up with NO issue's.
EFI IS the way to go.
Old Jan 25, 2005 | 01:08 PM
Sullivad's Avatar
Where is the fuel pump relay? I can certainly notice that the fuel pump does not prime when this problem occurs.
Like I said I put 2 hot packs on the electronic components under the seat and eventually it warmed them up to the point where they would work again and I did not get the trouble light blinking.
Is that relay located there?
The dealer decided to call Suzuki to find out what the error message C41 meant. I find that weird.
I think from looking at this site and others that I am the only one to exeperienc this, so I would not be really to worried about the EFI. I do find it start better than a carbed machine when cold...when it starts.
Old Jan 25, 2005 | 01:43 PM
bansheecraze32's Avatar
Old Jan 25, 2005 | 07:57 PM
tmac2's Avatar
Yep, the fuel pump relay is located right next to the ECM under the seat...
ltrmc02
Jul 22, 2015 04:50 AM
hondarider1234
Jul 21, 2015 11:53 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
