quadracer bore q's
first off as you know the piston and bore sizes are in millimeters. now to CONVERT millimeters to thousandths, you have to take the millimeters X .03937 to come up with the measurement in thousandths. now the stock bore size of the 88-92 LT's is 67mm so take that times .03937 and you come up with a bore size of 2.63779 (this is in thousandths of an inch), next find the size of the 68mm bore size, which would be 2.67716. next take the 2.67716 (68mm bore size) - 2.63779(stock bore size) and it should be .03937, which in turn would be .040 thousandths overbore in thousandths of an inch, because you have to hone at least a .003 thousandths clearance for the rings
so yes a 68mm overbore size would be the same as .040 over, i hope you can use this formula for the future times. and being a machinist this is easily second nature to me.
remember to get from mm to thousandths use this formula (mm X .03937=thousandths of an inch)
oh yeah and the .03937= 1 millimeter
later on
NichelsonRacing87
later on
NichelsonRacing87
Originally posted by: superevil
wiseco .com should have all the info you need
Originally posted by: trickeytech
that piston is to big for your 40 over bore
67.25mm = .10 over
67.5 mm = .20 over
67.75mm = .30 over
68 mm = .40 over
68.25mm = .50 over
68.5 mm = .60 over
68.75mm = .70 over
69mm = .80 over
69.25mm = get a new sleeve
Originally posted by: Semms40oz
67.25mm = .10 over
67.5 mm = .20 over
67.75mm = .30 over
68 mm = .40 over
68.25mm = .50 over
68.5 mm = .60 over
68.75mm = .70 over
69mm = .80 over
67.25mm = .10 over
67.5 mm = .20 over
67.75mm = .30 over
68 mm = .40 over
68.25mm = .50 over
68.5 mm = .60 over
68.75mm = .70 over
69mm = .80 over
Quadzilla Heritage
Sep 25, 2015 01:39 PM
