King Quad 700 Reverse light??
Old Feb 2, 2005 | 09:07 AM
ZLZ's Avatar
ZLZ
Default King Quad 700 Reverse light??
I have saw several post about a reverse light for the KG along with the heated grips. Where could you buy these from? THX
Old Feb 7, 2005 | 02:42 AM
05king's Avatar
I bought a set of off road racing lights in a small oval shape at Wal-mart for only $14.95. These lights had everything needed to install except you will need to cut the ends off and splice together with butt connecters. Then remove the rear plastic plate that says I.R.S. and I used zip ties to secure mine to the quad. When you remove the plate you will see two wires with female butt connecters I belive the orange is positive and the blue is negative. Put your kingquads brake on and put it in reverse and hook up a volt meter or test light to make sure. Be sure you turn the key on. I will find the lights and post the brand and upc code if you are interested. This was very simple to install.
Old Feb 7, 2005 | 01:53 PM
MonZooki's Avatar
so it is pre-wired to only come on in reverse...or are you just switching it?
Old Feb 7, 2005 | 02:22 PM
ZLZ's Avatar
ZLZ
I ended up buying a Warn ATV reverse light and mounted it on the back. I am using the existing wiring and it turns the light on when in reverse. Works pretty good.
Old Feb 7, 2005 | 08:06 PM
MonZooki's Avatar
cool, I'll have to buy a set of lights and sell one to my neighbor who just bought a KQ!
Old Feb 8, 2005 | 08:32 PM
ZLZ's Avatar
ZLZ
Here is a pic of mine mounted. It is right under the license plate. I had to make a mount out of wood so that the like wouldn't ground out on the frame. It worked out pretty good. You can't even see the mount hardly.
Reverse Light
Old Mar 26, 2005 | 08:57 PM
Judgedredd's Avatar
I used a 55watt tractor light from Walmart on my 04 Vinson. Works excellent! I posted a pick in my gallery!
Old Mar 27, 2005 | 05:20 PM
eiger2's Avatar
I used the wally lights too on my eiger, but had to install a relay.
Old Mar 8, 2006 | 01:25 AM
yellow700king's Avatar
reverse light
Old Mar 9, 2006 | 01:40 AM
DavAsh's Avatar
You can use any 12 volt light for the reverse. just make sure no to gound the light to any metal. The light is trigered by the groung wire and if you mount the light to metal or it touches metal it will stay on all the time with the key.
