2004 z400 mods help.....
Old Mar 18, 2005 | 10:59 PM
  #21
witti's Avatar
Default 2004 z400 mods help.....
I just ordered a 12.2:1 piston. Is it safe to put in the DRZ Base gasket with it. I am getting both hot cams and the drz valve springs. Would it be better to get aftermarket valve springs? I am also hoping to get my head ported.
Does the 12:1 piston come with gaskets? It might be the same as a stock piston with a DRZe base gasket, only a little lighter. If it uses the Z's 3 piece base gasket and you put a DRZe base gasket in you would be around 13:1.
The DRZe valvesprings seem to work great. They are a double spring instead of a single. IMO I would go with these and save a little money.
With my current mods listed in sig (still has jetting issues). I have raced a raptor with a stage 1 hotcam and Yoshi pipe and beat him the whole race. I had a lot more top end then him. He does weigh about 60 lbs more then me.
With cams, pipe, airfilter W/O lid I raced a Yfz with a WB silencer. We were within a quad length the whole race.
Im very impressed with the way the Z has responded to each mod I have done.
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
Sep 23, 2015 06:23 AM
