No smoke lt250r
Old Mar 7, 2005 | 04:22 AM
superevil's Avatar
Default No smoke lt250r
I am running a fresh 88 lt250r,paul turner pipe and fat boy silencer,stock airfilter and box, i have a 270 main jet and a stock pilot jet.the quad smokes like a normal two stroke when you first start it.but then it totally clears uponce it warms up. I can rev it to the moon while sitting there and it hardly "visibly" smokes. Is this a bad thing? OH YEAH,i checked the plug and it is black and wet,wich would lead me to believe its rich. i could smell the exhaust strongly but it doesnt seem to smoke hardly after warm up
Old Mar 7, 2005 | 04:31 AM
superevil's Avatar
BTW the quad starts up really easy,on first couple kicks usualy,and idles fine. i sprayed wd-40 around the base gasket while it was idling and it had no effect on idle at all,so my base gasket doesnt seem to leak. and my crank seals are new as well as the bearings,so i doubt the magneto side crank seal is leaking.
Old Mar 7, 2005 | 08:09 AM
allcool's Avatar
The new era of 2-stroke oils don't smoke if you are jetted right and the motor is in good shape. Once warmed up no smoke should be seen but you will smell the exhast... more if it is rich.
Old Mar 7, 2005 | 04:50 PM
superevil's Avatar
anyone else?
Old Mar 7, 2005 | 05:12 PM
kdog's Avatar
make sure you did the oil mixture correctly , you have water in it, Gas,Trans Oil, and JUST RIDE IT!
LOL
k-dog
Old Mar 7, 2005 | 05:44 PM
mahnster's Avatar
Theres nothing wrong with that.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
Levi Enstad
Sep 26, 2015 08:00 AM
bvolks
Sep 13, 2015 12:57 PM
