maybe its the valves
Old Mar 17, 2005 | 07:13 PM
02REC0Nrider's Avatar
Default maybe its the valves
I have an 03 Z-400 that is very difficult to start. To start it, I need to hook it up to a truck and pull start it, but after its warm, I can just push start it myself. The battery is dead, but even when hooked up to a jump starter, it wont run. Also, it only runs well on the Primary setting on the fuel tank. When i set it to on, it sputters and eventually stalls, even if i am applying the gas. Also, at idle, i can hear a noticable tapping noise that seems to be coming from the engine. I think that it may be a valve problem, but im not sure. Also, can anyone send me a link to a site or tell me who sells service manuals for 03 Z-400's for the cheapest price?
Thanks alot
Old Mar 17, 2005 | 10:51 PM
mucky's Avatar
sounds like the fuel petcock is really dirty inside. remove it from the tank and have it cleaned.
as for the noise it could be valves or a lose timing chain
and sounds like you have bad electical problem to work with. you should fix this first
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
