03 z400 chain adjustment
Old Mar 19, 2005 | 02:45 PM
Alec's Avatar
Default 03 z400 chain adjustment
ive had my z400 for about a month now. great machine. I bought it used, its an 03. The chain is too loose and i cant figure out the adjustment. any explanations on how to tighten the chain?
Old Mar 19, 2005 | 03:05 PM
garrett5462's Avatar
if you have an owners manual it's in there.
Old Mar 19, 2005 | 03:10 PM
Alec's Avatar
I dont have an owners manual
Old Mar 19, 2005 | 03:15 PM
ok then i can't help. if you look i think there is two or four bolts on the rear of the swingarm, and if you loosen them theres somekind of adjuster you move and i will move the whole swingarm back slightly.
Old Mar 19, 2005 | 09:24 PM
warrior226's Avatar
There are 4 bolts on the back and top of the swing-arm that have to be loosened, then adjust the bolts (the two sticking out the end of your swing-arm).
Old Mar 20, 2005 | 05:56 PM
Alec's Avatar
thanks for the info
Old Mar 20, 2005 | 11:07 PM
trenters's Avatar
hey, you have to make sure you take the brake caliper off first, and make sure you turn the two bolts on the back of the swing arm evenly to get even wear.
Firefighter400
Oct 8, 2022 06:38 PM
fordfaithful21
Dec 7, 2015 05:52 PM
goosemasterkl
Aug 23, 2015 11:36 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Jul 15, 2015 02:07 AM
