z250 need help fast!?!?
I really don't know they didn't give me any cost sheet since it was a Freebie but they sure did make it sound and look like it was a pain in the ****!! They had it for at least two weeks. I bought the extended warranty just for the driveline purpose, I can work most things on the quad but that driveline just seems to fall in the same catagory as vavle grinding don't want to mess it up!
Meischeech is most likely right. If it was a ring and pinion problem it probably would have ground or growled before giving up. I have replaced rear drive shafts, and pinion gears (never on a z250 though) and it wasn't that big a job. It's not something I would would be afraid of with a factory manual. I woulnd't expect it to cost over $200 if you did it yourself.
Originally posted by: rolsmojave3
NICE kfx MeIsCheech...like the way it sits
