Backfiring question
Old Sep 26, 2000 | 09:37 PM
ACdude's Avatar
I've got a '00 quadrunner 500 and when i run it a long time and cut if off or go fast and slow down quickly it back-fires. Any idea what to do about it? Its idleing fine(not to high), and ive drained the carb one time just to see if its getting to much gas or something, but anyway please help me out. thanks
Old Sep 26, 2000 | 09:44 PM
bullgod's Avatar
The main jet is probabley alittle lean
Old Sep 26, 2000 | 11:08 PM
ACdude's Avatar
thanks ill try to adjust it some, didnt think of that
Old Sep 28, 2000 | 10:11 PM
ecorman1's Avatar
ACdude, go to the Tech Threads, here and you will probably get to the root of your problem. But you are not running lean. Sounds like you're too rich or timing is off. Get help from someone who knows small engine repair if possible.
Good luck...
Chuck, Suzuki KQ 300, GPS & lunch...
Old Sep 29, 2000 | 07:53 PM
quad500's Avatar
Check your air filter, when they get dirty in my 98 quadrunner the machine tends to backfire, i helped the problem by installing a Uni Filter...
Old Oct 4, 2000 | 02:53 PM
SKQ300's Avatar
If the drain plug for soot is lose or off on the back end of the spark arrester it will backfire. Check to see if these are secure.
fordfaithful21
Dec 7, 2015 05:52 PM
Bigtwin700
Sep 9, 2015 09:32 AM
black798
Sep 9, 2015 07:42 AM
Rooky
Sep 9, 2015 03:16 AM
Brandon400
Sep 7, 2015 12:20 PM
