water in crank case
Old Apr 1, 2005 | 03:32 PM
dcb's Avatar
dcb
Default water in crank case
oil is milky white.
What is the best way to flush the crank case?
Thnks Dave
Old Apr 1, 2005 | 04:37 PM
hellyeh's Avatar
Eternal Rider
Building A Runway To Hell & Back!
The engine is the heart of an airplane, but the pilot is its soul. ~Walter Raleigh
Buy a couple cheap filters and enough cheap oil to do a couple oil changes. Let the quad sit for awhile , the water will separate from the oil and end up on the bottom of the crankcase. Drain the fluid and change the oil and filter with the cheap stuff , run for a bit and repeat. Once you are comfy that you got the water out , revert back to the quality oil and filter and your good to go. If you swamped it bad change the fluid in your diffs as well.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
SDR-II
Sep 29, 2015 01:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
