Z-250 HELP!!!!!
Old Apr 3, 2005 | 04:33 PM
SuZuKiRiDeR32's Avatar
Default Z-250 HELP!!!!!
I put my z up on its grab bar so it was sitting on two wheels and it started leaking gas everywhere??? I looked in my manual and it says that the bikes can be put like that and shouldn't have any problems. Also when I ride I run out of gas quickly so I know there is a leak I just dont know where, has anyone had this problem?
Old Apr 4, 2005 | 06:41 PM
SuzukiZ250Kid's Avatar
What is the little **** on the left side set to? It should be set to "On." You may have it set to "Prime" which could flood the carb and cause it to come out of the overflow tube.
Old Apr 4, 2005 | 09:03 PM
I looked it was on prime.... so if I turn it to on can I put it on its back wheels without having it leak gas?
Thanks
Old Apr 4, 2005 | 10:21 PM
You should be able to. I'm not promising it tho.
Old Apr 5, 2005 | 12:51 AM
Sweet thanks for the info[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 5, 2005 | 04:45 PM
By the way, after you stand it on end, check your airbox. There might be a little bit of oil in it that comes up threw the breather hose and work its way threw the airfilter and into the bottom of your airbox.
Old Apr 5, 2005 | 06:15 PM
ElectricShift's Avatar
Don't ever leave your Z on prime for a long time...
Old Apr 6, 2005 | 07:16 PM
Sweet... Thanks for all the help....[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 8, 2005 | 05:44 PM
ADMAN's Avatar
Yeah, I had the same problem on my wife's 250 when I was putting the skid plates on. They said the valve would not let that happen. But, it just sat there bleeding all over the garage floor. Good thing I had cardboard under it at the time...
styelz
Aug 2, 2004 12:15 AM
BobVilla
Apr 13, 2004 12:24 AM
zquader
Dec 8, 2003 11:22 PM
DesertSportsman
Aug 28, 2003 02:32 AM
diaperdude
May 21, 2003 07:23 AM
