LT 250 R Cold starting problem
Old Apr 13, 2005 | 08:11 PM
Quad32x's Avatar
Default LT 250 R Cold starting problem
A little info first ; 88 lt 250 r , ftz motor , 41.5 ftz carb , ftz pipe and stock ing. The problem is when you first try to start it you will kick yourself blue in the face and then pull start it. Upon firing you can tell its like it was flooded but I never gave it gas while trying to start it. Once it clears out , it runs fine and can be easily restarted while still warm. I have no clue. Please help guys !!! Thanks !! Tim
Old Apr 14, 2005 | 09:20 AM
Quad32x's Avatar
bump
Old Apr 14, 2005 | 10:56 AM
sam250's Avatar
Check to see if the plugs is wet when you're kicking it over, if so, it's too rich. I would also check the compression and spark. Was it starting fine before or did you buy it like this?
Old Apr 14, 2005 | 12:00 PM
emmerth's Avatar
I agree with sam.
Pilot jet may be too rich or you may have compression issue
Old Apr 14, 2005 | 12:03 PM
Quad32x's Avatar
Hey sam , good spark and compression. Plug is wet on the cold start. Check the main jet ? Carb was jeted by ftz and I know the weather is much different up there. If main is to big , what would you suggest being a fellow Florida boy. Thanks ,Tim
Old Apr 14, 2005 | 12:05 PM
Quad32x's Avatar
Hey emmerth , Any idea what the pilot should be ? Thanks , Tim
Old Apr 14, 2005 | 12:40 PM
emmerth's Avatar
The main will not affect your starting but your pilot will. What year is the racer? What clip position is the slide set at? Also, where are located at and what is your elevation? You may have mentioned it???
Have you checked to see if your choke is working properly?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
garyt1975
Jun 5, 2015 08:53 AM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
