oil issues,expert advice needed please lt250r
Old Apr 19, 2005 | 03:02 AM
superevil's Avatar
Default oil issues,expert advice needed please lt250r
on my first couple oil changes after new shift forks,new clutch plates,and new crank and bore/piston,i am noticing these super super tiny little metallic looking specs in my oil,there seems to be a lot of it considering i think there should be none -not enough in there to form a little pile or nothing like that,they are just floating in there. The specs are so tiny you cant even begin to feel them with your fingers.any ideas on whats wrong or whats causing this? the quad runs/shifts excellent.
Old Apr 19, 2005 | 07:12 AM
1987LT250's Avatar
why did you have it rebuilt ? you blow a piston last time to where there could be fragments left in lower from last time?
Old Apr 19, 2005 | 11:02 AM
sam250's Avatar
My engine did the same thing after a top and bottom end rebuild. So did my friend's 250R. I only noticed it on the first oil change.
Old Apr 19, 2005 | 01:27 PM
Duneaddict's Avatar
New parts, especially clutch fibers will dirty your oil with particulate matter... This is normal
Also a good reason to change your oil often... I change mine after every weekend of use.
Old Apr 19, 2005 | 09:55 PM
sblt500r's Avatar
if you have pieces of your piston in the tranny oil then you have bigger problems. like a cracked crankcase.
Old Apr 20, 2005 | 04:33 AM
superevil's Avatar
im thinking its just the new clutch/shift forks,its not piston pieces or anything.the thing runs absolutely great.
Old Apr 20, 2005 | 06:52 AM
1987LT250's Avatar
good point read that wrong. was thinking of the metalic i seen on my top half of lower end when pulling my jug sorry. smack me!
Old Apr 20, 2005 | 07:43 AM
superevil's Avatar
hey 87lt250r,do you know a good place to buy a sleave for an 87 lt250r cylinder?
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
txkevin
Sep 21, 2015 02:02 PM
scaldwellk
Jun 19, 2015 05:08 PM
clsharky
Jun 8, 2015 11:38 AM
