carb question...help pls
Old Apr 25, 2005 | 09:18 PM
trickeytech's Avatar
Default carb question...help pls
i have a 88 250 r with the mods listed below, my problem is that when riding like in 1st or 2nd gear barely off idle it sound like its bogging, hard to explain but if i push the throttle a little more it takes off like a bat outa hell, it runs great other than that, like i say its just off idle a bit, kinda has a gurgling pipe sound like it needs something wether its more fuel or more air i cant tell. i have pilot jetted it up and down but nothing seems to change it, air screw helped some but not enough, anybody had this problem befor? any ideas for me to try? thanks..
Old Apr 25, 2005 | 09:23 PM
86LT250RFatty's Avatar
thats how all 2-strokes are.. its called POWERBAND! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 25, 2005 | 09:29 PM
my 3 others dont do that.... its like a flat spot, push the gas a little more and it does nothing different, then push alittle more then it picks up and gos on like it should... i know what your saying but its not that.
Old Apr 26, 2005 | 02:36 AM
MeYHymN's Avatar
Is it in all the way through 1st and 2nd or does it clear up after 1/4 throttle or so?
It definitely sounds like your engine is loading up w/ too much fuel which would mean it's in the carb adjustment somewhere. Could your choke be stuck slightly closed?
Old Apr 26, 2005 | 06:32 PM
rooster123's Avatar
Do you have a power jet on your carb. Are you sure the bowl is not over filling is your bowl overflow clear???
Old Apr 26, 2005 | 06:57 PM
hondabuster's Avatar
Sounds like the pilot jet is too big, or the air screw is too rich . When you say the air screw helped some...is that when you went leaner or richer? How many turns out is the screw?
Does this have reeds? They in good shape?
If you have an air box with lid...try a test ride with out the lid on...that will lean it out, and see if the symptoms improve.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
