Anyone know the stock float settings on 88' Lt250r?
Old Apr 28, 2005 | 11:23 PM
BuddLight's Avatar
Default Anyone know the stock float settings on 88' Lt250r?
I have been outbid on 3 manuals now. This would be a huge help in getting my carb fixed.
Thanks for your help,
Scott
Old Apr 29, 2005 | 12:42 AM
MeYHymN's Avatar
I'm not sure if this applies to the 250r. But one of two things. There's a line on the outside of the bowl that lines up w/ the float. Problem is, you can't see the float w/ the bowl on so you just eyeball it. Or w/ the bowl off while the carb is on set it level to the ground. That's the rule of thumb that I've seen, but it could be completely different on the 250r.
Old Apr 29, 2005 | 07:03 AM
1987LT250's Avatar
hey scott jasons buddy eh? welcome to the forums, my manual is over at csa but ill 2way him with answer tomm. if your in hurry search old threads i have answered it once i her before. get that thing ready cuz my cool heads in and im ready sat.
Old Apr 29, 2005 | 07:45 AM
1987LT250's Avatar
Thu May 13, 2004 7:17 AM
18-21 for base and 6-8.5 for head stock jets and for the stock 34 mikuni flatside carb specs areas followed in manual:
carb model:mikunitm34ss
venturi diameter:34mm
float level:10.9-12.9mm
air screw :2 turns out
needle clip position:3rd groove
jet needle:6pf63
standard main jet no.:240*
main air jet no. :2.5mm
needle jet no. :R-0
pilot jet no.:37.5
starter jet no. :110
OPTIONAL MAIN JETS 87-UP
NO. 200,220,250
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Stever6368
Aug 16, 2015 07:34 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Aitch
Jul 21, 2015 09:40 PM
