Vinson CV boot replacement
Old May 8, 2005 | 12:49 AM
stuck's Avatar
Default Vinson CV boot replacement
I have an inner CV boot that needs replaced. Any tips to make this job easier? I'll be picking up a new boot on Mon. and will replace it sometime this week.
Old May 9, 2005 | 01:53 AM
MeYHymN's Avatar
Something about taking the shaft and new boot to a transmission shop to reseat the band on the boot. Not sure as I haven't done it before, just what I've read from other posters.
Old May 9, 2005 | 09:31 PM
THECVMAN's Avatar
This is all done with the axle removed from the vehicle (let me know if you need instructions on that). The inner cv joint is very simple to remove. First you'll want to remove the clamps from the boot. Cut the torn boot away and you'll find a large retaining clip that goes around the inside of the joint just above the ball tracks. Remove the clip by getting behind it with a small screwdriver. Once this clip is removed the inner cage, race, *****, & shaft will come out all together (wrap your hand around this to prevent the ***** from falling out all over the place). You'll find a retaining clip on the back of the shaft, remove this with retaining clip pliers or a large screw driver to spread the clip open. Once this is removed you'll be able to remove the cage, race, & ***** all together at one time. Now your ready to install it on your new half shaft. Make sure the boot goes on first. Then place the cage, race, & ***** on the shaft making sure that the tapered side of the cage and race are facing toward the outer cv joint. Install the clip to hold it onto the shaft. Then fill the inner cv joint housing with grease and place it over the cage, race, & *****. Install the large clip. Now pull the boot down and install the large clamp. Then take a screw driver and place it in between the small part of the boot and the shaft and push the inner cv joint in all the way until it bottoms out. Then pull it back halfway (or to the mid range of the inner cv joint) and remove the screw driver and install the small clamp. Your now ready to install the axle back in the vehicle. If you have any questions or concerns you can PM me.
Thanks,
Danny
Old May 11, 2005 | 08:25 AM
stuck's Avatar
Thanks for the reply. I went ahead and did the job but now I'm not sure if I put the piece with the holes that hold the ***** into place on the right way. I didn't read this post until after I was done.
When I removed the assembly I removed each ball and the piece with the holes for a good cleaning. I can't remeber if the piece with the holes came all the way off or did it stay on the shaft until I removed the small gear looking thing on the shaft. I had to persuade the small gear looking thing with a hammer. A few hits and it came right off. Simply pulling on it didn't work. I'm not sure if the piece with the holes was all the way off or not. When I reassembled I put the gear looking thing on after I put the boot down over the shaft. I then put the piece with the holes over the gear and then placed the ***** in place. All went together fine. It's possible I have the piece with the holes on backwards if I'm going by your post. I did pay attention to the way the gear looking thing came off due to the splines on the inside being different on one side. The shaft is all assembled but I didn'y put it on the atv yet so fixing it now wouldn't be a big deal. Just pissed at myself now that I think about it.
Old May 11, 2005 | 02:00 PM
THECVMAN's Avatar
Hi Stuck,
Yes, it sounds like you have it on backwards. I would take apart and make the fix before attempting a ride otherwise it could cause the cage to break! It's like granpa used to say " if in doubt check it out". I think you'd rather have to deal with it now than to get stuck out in the trails. Good luck,
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
