Bent rim....will it affect my ride?
Old May 22, 2005 | 01:50 AM
quadessence's Avatar
Default Bent rim....will it affect my ride?
I hit a large root going about 35 on the K.Q. it defintely dingged up the rim....plus over 50 I feel a slight wobble. Whats up?
Old May 22, 2005 | 02:10 AM
Slinger's Avatar
Yeah, it's probably bent around the flatter surface about the lugs. I hit a tree with mine and it wobbles through the handle bars. The only fix is a replacement.
Old May 22, 2005 | 02:18 AM
SuzukiRiderz400's Avatar
yea the stock arent the greatest in the world anyway, i had the same problem, i hit a tree stump and the rims bent (done many times over the years)...not sure it effects it to much but it does in the long run, and makes it look like ur amature [img]i/expressions/face-icon-small-tongue.gif[/img] i recommend just buying stronger rims...tho may be pricey just might be for the best.
Old May 22, 2005 | 01:33 PM
Z40005BR's Avatar
Everyone in here, I just bent my rim and what you should definately NOT do is ride with a bent rim. The only reason is because of this wobble youre talking about. What it does is wobble your bearings right out and kill them.
Old May 22, 2005 | 11:46 PM
raptorider660's Avatar
you should get a new rim causeits not good to ride like that when i bent my rim the handle bars would pull me in from the rim
Frisky2050
Apr 9, 2020 11:19 AM
JackTheKing
Jul 14, 2015 09:09 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
