Are Cams worth it?
Old Jun 21, 2005 | 12:35 PM
Sledhed88's Avatar
Default Are Cams worth it?
Thanks, if you install hotcams as an example, do you need the stiffer springs or what are they for? What do the gastket and springs run for?
Old Jun 21, 2005 | 01:12 PM
witti's Avatar
Stiffer springs will hold up better at high rpm's (keeps valves from floating). They are not needed but most people reccomend them.
DRZe valvesprings are ~$10 each (4 total) from a local dealer. Base gasket is ~$12. Stock compression is ~11.3:1 the base gasket bumps it up to ~12.3:1. You will need to run premium gas with the higher compression.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
kodiacrunner
Oct 4, 2015 11:52 AM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
