Are Cams worth it?
Old Jun 13, 2005 | 10:41 PM
suzuki43's Avatar
Default Are Cams worth it?
I have a '03 Z400 and it is piped with a K&N air filter and I was wondering if cams are worth the money? Does it give you one more gear in the sand for climbing? Does it keep your 4-wheeler the same reliability as stock? Does it still run good?
Old Jun 13, 2005 | 11:44 PM
03hmfz's Avatar
yes it's worth it. depending on your riding style will tell you whether to get both or just one. I have both and love it.
Old Jun 19, 2005 | 10:37 AM
witti's Avatar
Cams would give you a nice gain. Woodward specialties has hotcams for $250.
Old Jun 19, 2005 | 05:38 PM
SuzukiDoug's Avatar
Is that 250 each???
Old Jun 19, 2005 | 09:42 PM
blackbird's Avatar
250 is for both .do the drz-e base gasket and both cams ,and drz springs. and it will pull forever.also buy a heavy duty aftermarket cam chain too
Old Jun 20, 2005 | 11:44 AM
MURDR's Avatar
Getting the hotcams will definantly help top end espeicially for drag racing purposes. The only bad thing about hotcams is that they produce some valve train noise. It drives me insane!!!
Old Jun 20, 2005 | 01:51 PM
SuzukiDoug's Avatar
I think I might go that route, it is just so damn much to have them installed. I need to work on a pipe and other things first I suppose!
Old Jun 20, 2005 | 07:04 PM
Skidooer's Avatar
I also have cams, drz gasket/springs. Nice gain, good pull, very happy.
As for the noise in the valves, it is noticeable but only really at idle. Other than that i dont see how it bugs me cus i never hear it when im riding.
You should think about putting them in yourself. Just cams are real easy and the base gasket is really that much harder. I had no experience rebuilding any engines what so ever and i installed bot my cams, drz gasket, springs, and new rings, and have 195psi compression now.
Old Jun 20, 2005 | 11:03 PM
Sledhed88's Avatar
These DRZ gaskets and springs are they from the bike or where? And is a better cam chain needed fopr hotcams?
Old Jun 21, 2005 | 12:10 PM
Skidooer's Avatar
Yes the DRZ gasket and springs are from the DRZe bike, which is the same motor except it has thinner gasket, better cams, heavier springs, higher rpm CDI, and bigger carb i beleive.
No a better cam chain is not needed. Check your tensioner and see how many clicks are left and unless it needs replaced you dont need to.
