How to put the chain back on Help!
Old Jun 21, 2005 | 05:00 PM
Warrior02man's Avatar
Default How to put the chain back on Help!
Ok.. chain came off and bunched up.. but i just kicked it into reverse and it came undone. And no cracking of the case occured. I was just wondering how I would put the chain back on the rear sprocket? do i have to take the chain off or is there some way I can leave it on and do it? Do i have to take the rear skid off? thx.
Old Jun 24, 2005 | 10:23 PM
Z40005BR's Avatar
The easiest thing to do would be to find the master link and just take it off, straighten the kinks and put it back on.
Old Jun 25, 2005 | 08:36 AM
ChewyR's Avatar
if you don't have your chain adjusted so tight you can do it much like a bicycle. Put the chain on the front sprocket, then put then lay the chain on the top teeth of the back sprocket and roll your quad backwards.
If your chain is too tight to do this you can try to take off the front sprocket, put the chain around both sprockets and re-install the front sprocket on the counter shaft.
Old Jun 26, 2005 | 06:15 AM
superevil's Avatar
Use the force-----couldnt help it,i use the bicycle idea
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
Sjrpp
Jul 5, 2015 09:04 PM
