Zilla Rear Brake Master Cyl. Piston Siezed, Need Help!!!!
Old Jul 3, 2005 | 08:24 PM
BoostedLT600R's Avatar
Default Zilla Rear Brake Master Cyl. Piston Siezed, Need Help!!!!
Any techniques on removing a siezed piston from a rear master cylinder? I have the entire assembly removed up to that point, but cannot get the piston out. I have tried pentrating oil, compressed air.... everything I can think of, but no dice on removing the piston.
Scott
Old Jul 3, 2005 | 09:44 PM
donzilla's Avatar
try putting the caliper in a vise . not too tight and have it so the small end of the piston is up . heat up the caliper some and try using a punch to hit it out . or in the bleeder hole sray some liquid wrench and try to tap it out . then in working it back and forth to try to free it up .
Old Jul 4, 2005 | 05:12 AM
no no, the rear master cylinder, not the rear caliper. The piece that is actuated by the rear brake lever.
Scott
Old Jul 4, 2005 | 09:43 AM
donzilla's Avatar
o . ok . well almost the same thing . spray penitrating fluid down the bolt whole and then turn it over and try punching the valve down and work it loose that way .
Old Jul 4, 2005 | 11:54 AM
quadracer325's Avatar
If compressed air didn't do it I'd get a new master cylinder, old one may have rust/corrosion built up in there that will cause more problems down the rode.
Old Jul 4, 2005 | 03:01 PM
emeraldisleatv's Avatar
Did you take out the circlip?
Old Jul 4, 2005 | 08:59 PM
Yes, everything except the piston is out.
Scott
Old Jul 5, 2005 | 03:08 PM
Maybe try giveing it shocks and plenty of penetrating oil, After that I don't know. BTW was the bike left idle that this happened?
Old Jul 5, 2005 | 05:38 PM
I bought the rolling chassis used, it sat outside for a few years. Alot of things had to be unsiezed but this is a PITA!!!!
Scott
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Sandman2.0
Jul 21, 2015 09:03 AM
