Tire pressure...
Old Jul 6, 2005 | 11:34 PM
SuzukiDoug's Avatar
Default Tire pressure...
OK I am trying to figure out tire pressures. If I lower the pressure what will happen and when I raise it? I have stock tires on both bikes. I am thinking that when I raise the pressure I will get less pressure and let me slide around and fish tail better and what not? Thanks [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 6, 2005 | 11:50 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
basicly the lower the pressure the more traction you will get
you can go down to 3lbs if you like......and at that point its a matter of maybe pinching a tire
if you go up to about 7 lbs and above,,,you will slide nice and spin way more
no need to ever go past 10lbs IMO
for trails i usaully run about 4-5 lgs in the rear and 5-6 in the front
if its really rocky,,,i may up it a pound
Old Jul 6, 2005 | 11:52 PM
Bing's Avatar
Super Quad Patrol
the stockers are 2 ply weakness at its best
replace them with some nice 6-plys when they wear out
what kind of riding do you do? terrain?
also,,,check all tires before each ride
you will be surprised how much they can vary from ride to ride (with low pressure gauge)
equal pressure is also very critical for safety (bike will handle erratically)
Old Jul 6, 2005 | 11:55 PM
SuzukiDoug's Avatar
I don't do any real serious trail riding some rocks and most of the time softer and/or sand type dirt. So far that is where I have been...
Old Jul 6, 2005 | 11:56 PM
SuzukiDoug's Avatar
Of course thank you for the info [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 7, 2005 | 12:10 AM
Bing's Avatar
Super Quad Patrol
when i said 3lbs,,,i meant only the rears (traction)
the fronts need to stay at at least 5 or the handling gets a little shady
Old Jul 7, 2005 | 12:12 AM
SuzukiDoug's Avatar
I think I am going to run about 5-6 lbs all around...
Old Jul 7, 2005 | 01:31 PM
ss97's Avatar
Lets Ride!
If your z400 has the Dunlop Radials you won't notice much of a difference until you get close to 10psi. Radials are designed in such a way that they can be run in various PSI configuration and still give you the same performace for the most part.
A hard radial will still get the same traction as a soft radial and lateral stability will only slightly increase. On a bias ply tire you will notice a bigger difference between a few PSIs than you will on a radial.
Old Jul 7, 2005 | 01:46 PM
SuzukiDoug's Avatar
Thanks I have the stockers so
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
