Quadracer with midrange stutter
Old Jul 25, 2005 | 03:27 PM
ChewyR's Avatar
Default Quadracer with midrange stutter
Normally I'm pretty good with engines, and I had this thing running perfect for a while but it has developed this mis/stutter at I what I would guess is around 5000 rpm under full throttle. Throttle response is good until this point and I don't have any issues with part throttle riding.
I have jetted up and down 1 step and not seen any improvement. I changed to a new spark plug with no difference as well. The powervalve is working correctly. I thought I had a blown head gasket so I replaced it, but it is still doing the same thing. The top-end is fresh as of the beginning of this season and it still has 180-190 cranking psi. Also I've repacked the silencer thinking this might be the cause.
So I'm a bit stumped. I was hoping someone might read this and have a suggestion. All I can think it might be is a bad stator or crank seal on the oil side, (the mag side was replaced when I did the top end).
It does have a small leak where the pipe slips on the header flange because I can see smoke shooting out when I first start it, but I can't believe that would be enough to cause this issue.
Any suggestions, from someone who has encountered similar problems?
Old Jul 25, 2005 | 05:04 PM
rolsmojave3's Avatar
had this happen on my bros blaster....a bolt from Gosh knows where got stuck in the reeds...made it run like that
Old Jul 28, 2005 | 05:40 PM
ChewyR's Avatar
In case anyone else ever has this problem it was my timing. I lined up the marks on the stator and its running stronger than ever.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Halffast17
Sep 11, 2015 02:30 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
EXaholic
Sep 9, 2000 02:19 AM
