04 eiger light problem
Old Jul 29, 2005 | 09:34 AM
eiger0304's Avatar
Default 04 eiger light problem
When I have my headlights on, my brake light and tail light does not work. When my head light is off my brake light will come using rear hand brake lever, but will not come on using foot brake. What gives?
Old Jul 29, 2005 | 12:32 PM
hondabuster's Avatar
Its probable, that the two issues are unrelated.
Check the bulb...the tail light filiment could be burned out, but the brake filiment is still good.
The back brakes good be out of adjustment, or the switch which is hooked to the foot brake lever has come off.
Just a couple of guesses.
Old Jul 29, 2005 | 12:55 PM
eiger0304's Avatar
HB, First thanks for the response. I understand the tail light fil. But why would the brake light only work when the headlights are off. Bike should not care if your headlights are on or off. As far as the foot pedal goes, I have had to adjust it before. Kind of a cheap set up. I have not torn into the bike yet, I'm just trying to clear out some cobwebs before I start. Kind of like a brain teaser, doesn't make sense till it hits you in the face. Then ya say " Ahhh thats it, now it makes sense".
Old Jul 29, 2005 | 01:59 PM
Now i see, said the blind man. I reread the question, and you said they both dont work with the headlight on. But the brake light works with the light off.
Ok , try this, check your battery voltage,and the connections at the battery. They should be corrosion free, and clean , shiney (where the connector touches the battery terminal)and tight. Then check the ground wire, for the tail light assembly.
Im thinking you have a high resistance in the circuit somewhere. It could even be the bulb to holder is a bit corrorded or crusty, or the contacts of the bulb.
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
