high maintenance*
Old Aug 2, 2005 | 05:52 PM
BlasterYZ250fKiD's Avatar
Default high maintenance*
Is a z400 or kfx400 high maintenance*.. if so or not how high is the maintenance compared to a yfz450/450r?
Old Aug 2, 2005 | 07:18 PM
RedGoblin's Avatar
The high-performance 450 thumpers are high-maintenance for a 4-stroke. The Z/KFX/DVX however is not nearly as much as the 450's. When I say "high-maintenance" though, all I really mean is that you'd be changing the oil and filter more so than the traditional 4-stroke. A rebuild may be in order more often as well, but I wouldn't think as much as a 2-stroke.
Old Aug 3, 2005 | 09:47 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The Z and its clones are not particularly high maintenance. If you do a reasonable oil change interval (I never go more than 20 hrs, usually less), valve adjustments, and chain lube, that is about all you are going to have to worry about on a routine basis.
The 450R on the other hand is such a high revver, that it needs very frequent oil changes. I never go more than 5 hrs on this machine! Some great advice about oil! http://www.thumperfaq.com/oil.htm Everything that goes for the CRF dirt bikes, also goes for the TRX450R.
Old Aug 3, 2005 | 10:09 AM
1of4Horsemen's Avatar
Pale Rider
With my goldfish shorts swimmin' around my toes.
The only maintenance you need to do to a Z/KFX is preventative maintenance for the most part. Like the others said oil & filter change, air filter cleaning.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
