Lt250r Stator???
Old Aug 8, 2005 | 05:04 PM
LT249r's Avatar
Default Lt250r Stator???
As we all know, the LT250R stock stator sucks, and is barely powerful enough for a light/tail light. So, what is a good stator that is powerful enough to handle a 60 watt headlight?(slyvania halogen cool blue headlight(55-60watt)
stator=magneto?
i am not sure what the stock stator wattage is, but i want a stator that can power a 60 watt bulb... (for a good price, around 100 bucks, but any comment is appreciated.)
Thank you
Lt249r
Old Aug 8, 2005 | 07:40 PM
10klt250r's Avatar
the stock stator will run that no problem, the aftermarket ones are for powering 90 to 110watts.
maybe you have a bad stock stator??? I have two extra stock stators in great shape if interested.
I myself bouth a (ricky stator) for $130.00 to run four 35watt lihgts. hope this helps.
Old Aug 10, 2005 | 07:59 PM
LT249r's Avatar
see, thats the problem though, the stock stator barely runs the bulb,(car headlight). it will turn on the light, but barely powerful enough to see on the road.
it runs the rear light fine, but the front, which was intended for a car headlight, barely. So should i purchase a lower wattage light, and maybe it would be brighter then, or buy a more powerful stator?
Cause i am not to sure that a lower wattage headlight will do the trick, but maybe you, or someone else will know?
Thank you
Lt249R
Old Aug 10, 2005 | 08:02 PM
LT249r's Avatar
maybe 2(or 1) low watt headlights like you have in red lt250r in your picture profile would be much brighter than one big high watt headlight?
Old Aug 10, 2005 | 11:51 PM
sblt500r's Avatar
if your stator is in good condition you can just buy the 2 lighting coils from ricky stator and wire them in. then you'll get the same output as a ricky but for a cheaper price.
ultangler
Nov 30, 2024 01:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
