suziki lt 125
Old Aug 17, 2005 | 01:54 PM
izzy3338's Avatar
Default suziki lt 125
I have a suzuki lt 125 and whenever I start the engine the idle goes out of control can someone help me?
Old Aug 17, 2005 | 06:16 PM
UGLY88's Avatar
Check for an air leak around the carb and intake, or a stuck choke?
Old Aug 17, 2005 | 07:50 PM
dunbarr's Avatar
adjust ur idle screw I'm betting on that
Old Aug 18, 2005 | 12:26 AM
izzy3338's Avatar
i found out there was an o-ring missing from the end of the pilot screw
Old Aug 18, 2005 | 12:27 AM
dunbarr's Avatar
explains it ....maybe
Old Aug 18, 2005 | 04:58 PM
izzy3338's Avatar
nope it wasnt the pilot screw. where would there be an air leak?
Old Aug 18, 2005 | 05:11 PM
UGLY88's Avatar
Like Dunbar said check adjust the idle screw after it is started and warm. If this does not change anything make sure your choke is not on or stuck on. IF this still does not fix the problem, check for air leaks by spraying with starting fluid or carb cleaner around the intake connections. to each side of carb and around carb in general. If there is a leak the idle should change. Maybe there is a tear in the intake tube? These are all stabs in the dark since we do not have much info to work with. Let us know. what happens.
PTG
May 30, 2011 11:34 PM
kornleash
Sep 22, 2010 10:31 PM
lhernandez
Sep 1, 2009 04:55 PM
ddemars
Jul 23, 2009 10:14 PM
fellas2
Aug 26, 2008 12:21 PM
