Water Wetter
Old Aug 23, 2005 | 07:35 AM
MIDGET's Avatar
Default Water Wetter
Has anyone used this? I have a 05 King Quad and I notice on very hot days my fan runs alot. I read if you use about 2 to 3 oz in your rad it will help keep cooler.
Anythoughts will be great.
Old Aug 23, 2005 | 08:26 AM
AtomicPunk's Avatar
I haven't used the water wetter but I do use Engine Ice in my Husaberg. These are known for running hot & I have used the Engine Ice since it was new w/o any problems including build up in the water jacket, on the water pump impellor etc.
It runs about $15-16 a half gallon and is used w/o the addition of any water, so you would need to flush your cooling system before trying it.
Old Aug 23, 2005 | 09:09 AM
500zuki's Avatar
I use it in both my quads and truck and have noticed a big difference. You need to drain all the coolant and run it with distilled water and it will run much cooler.
Old Aug 23, 2005 | 10:46 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I use it in all my machines, both off-road and street.
Nice demo on Redlines site of the principle of how it works (removes air from the coolant): http://www.redlineoil.com/products_coolant.asp
Actually, for maximum cooling, you can do what 500zuki suggests (just pure water and some water wetter), but BE ABSOLUTELY SURE TO REPLACE IT WITH ANIT-FREEZE COOLANT BEFORE THE COLD WEATHER RESUMES, or you will be in for a rude surprise. Water wetter is NOT a replacement for antifreeze!
If you ride in the warm southwest desert like I do (where it only freezes once every ten years), we can get away with it year round if you are very very carefull.
Old Aug 23, 2005 | 11:46 AM
MIDGET's Avatar
Ok.
Thanks for the info. I thought I could just take out some antifreez and just add a little to the system.
Old Aug 23, 2005 | 05:43 PM
Red Rider
Midget-We may have confused you. For the average recreational rider, just add the recommended amount of water wetter to your antifreeze/coolant.
Running water wetter in water, is just for those who want the maximum possible cooling that is obtainable. That's just for racers and guys like me who ride in the desert.
Old Aug 23, 2005 | 05:59 PM
MIDGET's Avatar
Thanks,
All I want to do is just add some to help to keep it a little cooler.
I will read the bottle and just add some to the quad.
Thanks agin.
Old Aug 23, 2005 | 07:43 PM
garrett5462's Avatar
hey, i was wondering if you use the watter wetter, does it change the coolants freezing point?
Old Aug 23, 2005 | 09:57 PM
Red Rider
No doubt it changes the freeze point slightly, but I doubt it makes any practical difference at the temperatures in the lower 48 states.
Old Aug 24, 2005 | 10:24 PM
redfishdaddy's Avatar
Changing your coolant temp also messes with the O2 sensor? The King is fuel injected. Most fuel injected vehicles like a hotter engine?
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
