King Quad reverse problem - 2005 vs. 2006
Old Aug 30, 2005 | 01:28 AM
  #21
kion's Avatar
Default King Quad reverse problem - 2005 vs. 2006
Is the VIN # on the frame of the bike the same that the one on the engine casing...
Old Aug 30, 2005 | 02:44 AM
  #22
dshoe's Avatar
Originally posted by: stocks
thanks Glen!! Good then to hear that above '05's are good as well as all of the '06's!
Are you thinking about searching for a good 2005 now, or are you still planning to wait for a new 2006?
Old Aug 30, 2005 | 02:59 AM
  #23
Glenlivet's Avatar
Not necessarily. But it's the motor that counts.
Old Aug 30, 2005 | 06:43 PM
  #24
stocks's Avatar
dshoe, I am in the market for an '06 for one main reason....the job. My company is moving to Hartford, CT by year end and I need to firm up my next job before I buy because I am staying in St. Louis. If that aspect didn't exist I would probably still be waiting for an '06 and it has nothing to do with the '05's with the correct serial # either.
What are you thinking you will do?
Old Aug 30, 2005 | 09:04 PM
  #25
Mcgill72143's Avatar
Suzuki's letter about the reverse problem didn't say anything about the number's on the moter but only the last #'s of the vin on the frame....anything above 52115956 has the updated gear and ecm...
Old Aug 30, 2005 | 10:03 PM
  #26
razcob's Avatar
I heard this also, it was the frame vin #, got it from highlifter.com. I hope we can get a definate answer on this. Aren't the engine and frame vin plates supposed to match like cars?
Old Aug 31, 2005 | 01:17 AM
  #27
kingme's Avatar
One thing to consider if you are in the market. The late 05 king with the fixed reverse will still carry a 5 year warranty on the reverse. An 06 king will carry the standard 6 month. With the needle bearing fix Im sure it will never be an issue just thought some would like to know.
Old Aug 31, 2005 | 08:42 AM
  #28
budlyte's Avatar
I agree that it's the VIN# on the frame and not the motor.
Old Aug 31, 2005 | 05:36 PM
  #29
razcob's Avatar
Originally posted by: Glenlivet
On the motor casing near where you put the oil in.
Dude, I pulled the side panel and couldn't find a serial number. There is a sticker on the frame below the dipstick, but it doesn't have a serial #.
Old Aug 31, 2005 | 05:42 PM
  #30
Vincereeder's Avatar
razcob, my # is on the other side of the motor, I didn't have to pull any panel off, It sounds like your vin # is the one to go by, without looking on the quad, my dealer wrote it on my sales reciept, I just made the cut, i am above the magic number !!!!!!!!
