engine oil
Old Sep 16, 2005 | 06:06 PM
dvxxvd's Avatar
Default engine oil
what is the correct way to check the engine oil on a Z-400, do you do it with the engine hot or cold. My oil leve is all over. Sometimes it will be fuill and sometimes empty. It is not smoking at all or leaking. Also do you screw the dipstick all the way in or just put it in and pull it out. It is an 05' so there better not be any engine problems. Thanks.
Old Sep 16, 2005 | 07:27 PM
dvxxvd's Avatar
Default engine oil
i read in one of the kawie fourms that little black box on the RH side has something to do with the oil. I havew took thew one 8mm bolt out to move it out of the way so i could turn the carb a couple times, mabye this has something to do with it? any ideas?
Old Sep 17, 2005 | 01:34 AM
yoshz's Avatar
Default engine oil
Check your owners manual. I don't have mine handy, but you are supposed to warm it up and don't screw the dipstick in if I remember correctly. When it sits, the oil drains out of the reservoir so even if you warmed it up, if you let it sit for a while, you won't get a correct reading.
Old Sep 17, 2005 | 05:17 PM
dvxxvd's Avatar
Default engine oil
alright ill check but thats good to hear thanks alot
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
