z400 strange ticking noise//
Old Sep 21, 2005 | 04:25 AM
RADWHEELER03's Avatar
Default z400 strange ticking noise//
THE LAST TWO RIDES MY Z 400 HAS STARTED MAKING A LOUD CLICKING NOISE ALSO RUNNING IN 5TH GEAR JUST CRUSING IT BACKFIRED AND DIED. hOWEVER AFTER STOPING IT FIRED RIGHT BACK UP. dOES ANYONE HAVE AN iDEA AS TO WHAT MY PROBLEM MIGHT INTEL . WOULD APPRICIATE ANY FEEDBACK . THANKS RADWHEELER
Old Sep 21, 2005 | 07:55 AM
QuadN00b's Avatar
Ease off on the caps. Anyways, how old is your bike? Sounds like its your timing/cam chain.
Old Sep 21, 2005 | 01:16 PM
Riderr's Avatar
engine knocking[img]i/expressions/face-icon-small-shocked.gif[/img]
10 bucks says u never check oil and filter.
Old Sep 21, 2005 | 04:17 PM
ss97's Avatar
Lets Ride!
Well if it's just a slight lean-type valve tick, and it backfired and died, try adjusting your idle/air screw. This may sound silly, but I once landed really hard on a jump, dead sailored it left front first, but I guess the impact messed up this adjustment and the quad was backfiring, stalling and would not idle.
One little turn and everything was back to normal.
Old Sep 21, 2005 | 08:12 PM
stuffstuff's Avatar
mabey u need your valves ajusted. my 400ex was making a loud ticking noise then got the valves ajusted and it stoped
Old Sep 21, 2005 | 11:26 PM
mucky's Avatar
sounds like timingchain or valves need adjusted
and welcome to the forums
Old Sep 22, 2005 | 03:36 PM
ss97's Avatar
Lets Ride!
Way too soon for valve adjustments on that engine.
The 400ex engine is known for valve adjustments, seems to be a Honda thing more than anything else.
The DOHC engines require far less frequent valve adjustment. Check the plug to proper burn before you go there.
Old Sep 22, 2005 | 03:46 PM
LTZ's Avatar
LTZ
Not entirely true. The valves should be checked and adjusted if necessary after break-in on all quads.
Old Sep 22, 2005 | 03:58 PM
witti's Avatar
What he said.
I had to change the chain on my 03 Z.
I would pull the cam chain tensioner and see if its maxed out.
HOW TO CHECK YOUR CAM CHAIN-
Pull the center bolt and spring out of your tensioner (RR side of cyllinder). Then remove the upper and lower bolts, pull the tensioner out and see how many clicks you have left before the center shaft is all the way out. Release the lock on the center shaft, push it back in, reinstall the tensioner and outer bolts. Then install the spring and center bolt.
Old Sep 22, 2005 | 05:06 PM
HEY TRAILBLAZOR YOU OWE ME A TEN SPOTY ,I HAVE MORE RESPECT FOR MY MACHINES THAN THAT BUT THANKS ANYWAY[img]i/expressions/face-icon-small-disgusted.gif[/img];RADWHEELER.
