z gearing
Old Sep 24, 2005 | 11:43 PM
Sparky8370's Avatar
Default z gearing
PS-mucky
if she was christine wouldn't she have beat the hell out of someone else then fix herself if she got damaged?
Old Sep 25, 2005 | 03:10 PM
mucky's Avatar
Default z gearing
everytime she's been wrecked its alway me that gets hurt
Old Sep 25, 2005 | 04:57 PM
TrevR's Avatar
Default z gearing
Thanks for that chart, i think i will start off by droping 1 tooth up front , a primary drive unit, thats the only one i have found, renthal had stock or plus 1 but no -1, is the primary drive a good sproket? found it for 6.99
thanks for your help!
Old Sep 25, 2005 | 08:53 PM
welby's Avatar
Default z gearing
I run Renthals, but I've heard only good things about Primary Drive.
Old Sep 26, 2005 | 02:48 AM
  #15
kawiking's Avatar
Default z gearing
i have the primary drive sprocket, it works fine. 1 tooth down will help out alot. i ride alot of trails and sand. felt a big diff on sand and all i got to say about the trails is becareful. felt like alot more torq!! helped on the hills but will bring that front end up pretty fast. good luck and have fun!!
Old Sep 26, 2005 | 01:48 PM
  #16
BlackKawi400's Avatar
Default z gearing
I run a 13T front with 18" Rears and still hit almost 80, although 1st gear is pretty useless to me.
Old Sep 27, 2005 | 02:07 PM
  #17
nhm90's Avatar
Default z gearing
Do you have an aftermarket CDI?
According to the calculator above, you would need to turn 11.5K RPM in 5th to reach 79MPH with 13/40 gearing and 18" rear tires.
Old Sep 27, 2005 | 03:06 PM
  #18
Default z gearing
Yeah. Thats definetly how I hit ALMOST 80, more like 77, but still...... My 1st gear is useless, and I'm thinkin I will probably go back to the stock gearing or go up to 20" rears.
Old Sep 29, 2005 | 02:52 PM
  #19
TrevR's Avatar
Default z gearing
when you replace the front sprocket the two bolts that go into it do not go into anything behind it. how is the sproket held on?
i just put mine on last night it was simple but i cant figure out what the two bolts do? also the stock washer does not fit with the
smaller sproket? do i need to find a aftermarket washer? primary drive did not include one. thanks
Old Sep 29, 2005 | 03:57 PM
  #20
Default z gearing
The sprocket goes on with the splines just past the groove in the shaft. Then the washer with the teeth slides on and you turn it to line up with the holes in the sprocket. The teeth of the washer travel along the groove and then stop behind the outer section of the splines, holding the sprocket on. Then the bolts hold the washer to the sprocket.
