BLOWN LT250R QUESTION???
Old Oct 3, 2005 | 09:21 PM
CoffeeRoasterDS650's Avatar
Default BLOWN LT250R QUESTION???
Looking to find out if there should be any lateral play in the connecting rod at the bearing inside the cases??? I can slide it side to side.
Thanks!
Old Oct 4, 2005 | 12:46 PM
rooster123's Avatar
Yes it will slide side to side. And you will feel a little play holding the rod and moving it back and forth. But you should have no play up and down.
Old Oct 4, 2005 | 02:38 PM
superevil's Avatar
I would have it checked out by a professional,because sometimes its hard to feel the up and down play unless its bad
Old Nov 3, 2005 | 12:40 PM
blee's Avatar
do the ping test.
pretty sure you need to have the crank out of the cases.
hold the crank up by the rod,
in your hand,
then hit the top of the rod with a RUBBER mallet / hammer.
if it makes a "ping" or "pinging" noise, its bad...
if its really quiet, its good to go.
Old Dec 12, 2005 | 02:58 AM
cyanidetrece's Avatar
i've always heard that a ping is good. a thud sound means you have a cracked crank. you might want to look into that.
Old Dec 12, 2005 | 10:06 PM
sblt500r's Avatar
ping is bad, no noise is good. i've never seen a cracked crank, how would a crank get a crack?
bmxatv10
Oct 14, 2022 06:23 PM
fd24
Jan 16, 2019 08:59 AM
bigred20653
Oct 2, 2015 10:05 AM
Halffast17
Sep 11, 2015 02:30 PM
byronman
Sep 6, 2015 06:34 PM
