Exhaust tip ?
Old Oct 16, 2005 | 11:52 AM
gooch400's Avatar
Default Exhaust tip ?
Has anyone ever used a billet exhaust cap on there stock muffler? The opening is WAY bigger to breath more.
Is it worth it & did you re-jet?
Old Oct 16, 2005 | 02:46 PM
Torbinx's Avatar
Hey,
What I did was took my end cap off and and put it in a vice. Next I sawed the spark arestor off with a hack-saw. Then I tookt he drill and put a small drillbit in big enough to drill inbetween the insert tube and the outter shell. I drilled about 13 holes around it and broke 2 drillbits in the process. The area left inbetween holes I would drill and slide the drillbit around. Then I took a solid metal pipe big enough to cover the insert and hit it with a hammer and that insert eventually popped out. I was left with jagged pieces of medal all around, so I took the high speed air dremel tool with a grinding tip and grinded it all smooth perfectly as big as it goes. I liked the difference in sound and no I didnt rejet. Ive been on a few trips since and no problems.
Old Oct 16, 2005 | 07:29 PM
gooch400's Avatar
Thanks for the info. I found a nice looking billet end cap on e-bay and it has a spark arrestor in it. Gotta keep the forest dudes happy..
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
