top speed with the z400
Old Oct 18, 2005 | 09:52 PM
mikesz400's Avatar
Default top speed with the z400
does anyone know approx. the top speed of a 05' suzuki z400 from the factory? what about with a jet kit and pipe with the original wheels/tires and sprockets.
Old Oct 19, 2005 | 12:22 AM
powerstroke01's Avatar
All stock i hit 70. Supposed to be able to hit 72. Close enough. haha
Old Oct 19, 2005 | 03:14 AM
MIDDLEAGEDCRAZY's Avatar
I also hit 70 mhp. clocked it with my dodge dakota at the Jean dry lake's bed.
Old Oct 19, 2005 | 01:05 PM
SuzukiDoug's Avatar
I hit about 68-69 MPH according to the GPS and that was about all I could do.
Old Oct 19, 2005 | 05:54 PM
strongtyerYFZ's Avatar
What about my Z? Dr. D exhaust, K&N airfilter, BIG GUN CDI... Mid to high 70's or lower? All my mods are in my bio but those should be all the engine mods.
Old Oct 19, 2005 | 06:17 PM
Raptor0502's Avatar
mid 70's
Old Oct 19, 2005 | 06:50 PM
dvxxvd's Avatar
hey my rev limiter kicked in at 73mph when stock so adding a pipe and and filter won't give much more top speed. However you can then gear it higher like i did. Now its close to 80mph. Also it can do way better catwalks because stock gearing normally by the time you get it up its about powerd out unless you go really far back. With the gearing i have (one size bigger front sprocket) it can go forever.
Old Oct 19, 2005 | 08:17 PM
Wait... I have a Big Gun CDI too. It makes the rev limiter kick in later. Higher RPM's means more revolutions per minute or second or whatever so the sprockets will be spinning faster at 8000 RPM's than compared to say 7800 for example. That should give me a little more top speed. I have 20" tires running stock gearing (I just changed my sprocket from one tooth lower back to stock). I'm thinking more like higher 70's with those 3 mods... pipe, airfilter, and CDI if Z400's go 70-say 73 stock. Maybe a 5 mph increase. Not that top speed matters that much. Just kinda curious. Its nice to know how fast your quad is so when someone asks you can tell them but personally I think acceleration is more important.
Old Oct 20, 2005 | 01:42 PM
Rickmaff's Avatar
[i]but personally I think acceleration is more important.
Acceleration is most important, and remember this, would you rather have 1st, 2nd and 3rd gear, or 4th and 5th
Old Oct 20, 2005 | 11:02 PM
Well you couldnt do anything with just 4th and 5th gear anyways... You couldnt get moving to those gears without at least 2nd and 3rd.
