04 Eiger 4wd cable
Old Nov 1, 2005 | 09:35 AM
alleycat's Avatar
Default 04 Eiger 4wd cable
Is their an adjustment for the 4wd cable on the Eiger? The problem I am having with mine is it seems to not want to disengage all the time, or it will disengage when I start driving again with a clunking sound. Thinking the cable might not be fully disengaging the system.
Old Nov 1, 2005 | 05:51 PM
rolsmojave3's Avatar
if you take off the black plastic inside of the front tire you can get to the adjuster for it....it's right on the Diff
Old Nov 2, 2005 | 09:26 AM
Rags1317's Avatar
There is also an adjustment ubout 6" under the lever. Just jack up the front wheels and spin them while moving the lever. I have an 02 and have had to adjust it twice.
Old Nov 2, 2005 | 11:50 PM
alleycat's Avatar
Thanks guys, found it under the speedo housing. That fixed the problem. Thanks again. You think they would mention that in the owners manual.
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
craacker
Sep 9, 2015 04:32 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
