86 LT250R tranny siezed ??? help
Old Sep 19, 2005 | 07:44 PM
f250r's Avatar
Default 86 LT250R tranny siezed ??? help
hey guys my buddy just bought an 86 LT250R for 500 bucks needed a wiring harness. thats it the entire top end is brand new. we were geting ready to check for spark and we kicked it over and the kick stater seized right in place and the shifter wont move either. It kick over when we picked it up. I took the jug off and look it over im no tranny mechanic but i can do everthing else. The piston was not such in the bore, the whole thing was locked up right from the crank. you can spin the back tires with some force. This puzzles me anybody got any ideas ?????
Old Sep 19, 2005 | 08:38 PM
DavidLT250S's Avatar
tie it behind the truck and go down the road and see if it loosens up?
Old Sep 20, 2005 | 03:34 AM
superevil's Avatar
well i definitely wouldnt pull it with a car,it sounds like someone may have assembled the tranny wrong,first i would take the clutch cover off and the stator cover off and make sure everything under those is put together correct,you might get lucky there,check the external shift stuff behind the clutch basket,but im willing to bed somoene hacked the tranny together
Old Sep 20, 2005 | 07:04 PM
f250r's Avatar
yea, tranny sounds like sombody screwed with it. He brought it to a guy that works on racing quads so will see
Old Nov 2, 2005 | 03:26 PM
blee's Avatar
i gotta 86 engine for sale.
perfect, 100% rebuilt. painted, everything new. crank/rod/piston/bore.
rode for under 10 hours, break in stage completed. check my page / gallery on here for pics.
Old Nov 3, 2005 | 03:11 AM
hometheaterman's Avatar
Hey Blee I know you from Pavementsucks.com I had never seen you on here before? How much you want for that engine? I am not sure I want to put an 86 in and I do have most of the parts for mine but it is causing me trouble as it not only had the top end sieze up it is now leaking tranny fluid as fast as I can put it in. I hope a case isn't cracked when I get it apart and it is just a seal or gasket.
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
kester_holmes
Sep 10, 2015 08:27 AM
Logan Collins
Sep 5, 2015 08:03 PM
Haakon
Aug 24, 2015 01:54 PM
