suzuki ltz 400 water in oil
hi, just wondering if anyone has ever had problems with water in there oil on there ltz. (headgasket, waterpump seal etc..) i have a kfx but since suzuki made the motor and shared them . just thought i would ask. thanks in advance for your help
my buddie has one also and it has been bullit proof. so i bought one at a auction changed the oil and it was milky bad!! a extra quart worth. rode it for 2 hours and then changed it again not as bad but deffently plenty milkey? scott
it changes in the over flow tank. so it tough to tell, when i first got it it was low. now i filled it up it is staying steady but i only rode it 2 hours and it won't take much water to make 2 quarts milkey.
If I seen water in my oil I would instantly tear it down at least to the top of the piston. This is very cheap aned would probably answer your question. You can do this with the motor still in the bike.
If yours is an 05 or 06, they are doomed with the problem that suzuki made the clutch/coolant covers of magnesium. These covers are known to corrode at very quick rates, even with the manufacturer's provided fluid. The 03/04's dont ahve these problems but do have a rep for frames cracking. Take your choice... It is really ashame for such a nice bike to be stuck with these annoying probs. Suzuki will probably be making a recall soon as they are aware of it. I have heard of people installing 03/04 aluminum covers on their 05/06's. This should fix ur prob. I suggest not riding again til u fix it, jus drain it and replace the caps. Hopefully you have some kind of warranty. I am also pinned with the problem that I know that one day mine will leak too. I jus bought an 05 about a month ago. Plan on gettin it in on my warranty still.
Hope this helps, also look for the other posts on cover corrosion.
