QUADRUNNER ?,S
Old Dec 4, 2005 | 08:00 AM
akarotten's Avatar
Default QUADRUNNER ?,S
Someone explain tire size #,s to me [like 24-11-10] and would that be the only size tire to fit the rim tire,s on?One more ?,where can i get air filter oil for a stock filter,only quad place near here said i could use 10w40 moter oil,dont think he,s right,but not sure.Thanks,Paul[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 4, 2005 | 09:10 AM
Scooter86's Avatar
Knows Old ATV Questions!
in your example, 24" would be the tire diameter, 11" the width, and 10" the rim diameter. You would need to chose from other tires with the last number "10" I wouldn't use motor oil for the air filter. It might work OK on an emergency type situation, but true filter oil has some tack to it to help trap dirt, while motor oil is designed to be slippery, not tacky. Just about any kind of motorcycle shop will have the filter oil you could use, it doesn't have to be a place that sells dirt bike/atv's. If you don't have anything close by, then time to go mail order or internet.
Dammar
Apr 20, 2016 06:03 AM
phummer3210
Sep 11, 2015 03:47 PM
Sep 1, 2015 11:59 PM
Thwapp
Aug 25, 2015 09:54 AM
Bulgin88
Jul 30, 2015 05:20 PM
