Quadracer problems.....again !
Old Nov 1, 2000 | 08:02 PM
jfboy's Avatar
When putting the cluch shaft back on, the fuc*&%g part that sticks out of the cover and is suppose to hold the clutch cable broke off. I'm getting tired of this quad ! has this ever happen to anyone ??? How do I fix this ??? ............Wait I know ! trow that motherf*&^ng lemon in a lake and get a 400ex
Old Nov 1, 2000 | 08:17 PM
92LT's Avatar
That is a common problem. Instead of buying a whole new side cover, you can buy just a bracket that bolts on using the side casing bolts. I think that nac's and james lucky sell these, but i don't know for sure. Hopefully this will be your last problem. Good luck.
Old Nov 1, 2000 | 08:36 PM
jfboy's Avatar
how do I contact them ??? How much will it cost me ???
Old Nov 1, 2000 | 11:09 PM
92LT's Avatar
Ok, I found it for sale at Nac's racing - (914-246-3086). It is $29.99, fits 87-92. Nacs advertises in dirtwheels magazine. I've never dealt with them, so I can't say they are a good company to deal with. That is the only place I found it now. It seems kind of expesive for just a bracket, but I think it will be much cheaper than a new side casing. Look around, I'm sure I've seen it elswhere cheaper.
Old Nov 1, 2000 | 11:47 PM
jfboy's Avatar
Yeah I just saw that ad too. I'm gonna order that as soon as I can. Meanwhile I fixed it with some extra strenght tape. I put the part that popped off back on what was left. It seems to work, but as soon as I'll get in a puddle...........
Also there is another thing on my quad....I'm replacing the spark plug every ten minutes. It'll run fine with a new spark plug but after a while it will die. After that i can still start it but I cant give it any gas or it will die. Its probably the carb........I tried playing with the air screw but it did not help.
PS: take note that I bought my quad in Canada and brought it down to Georgia.
Old Nov 2, 2000 | 12:25 AM
scramdaddy400's Avatar
Man, I get suckerd to fix the same problems with my girlfriends LT250R. I can tell you whats wrong with the spark plug and carb.
First off did you gap the plug and is it a B9EGV, and about that jetting sounds to me like theres to much gas, buy a couple size smaller main jet. And starting from closed position on your air/fuel screw turn 1 3/4 turns out.
Lets put it this way I know more about her atv than I do mine.LOL.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Halffast17
Sep 11, 2015 02:30 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
jfboy
Nov 8, 2000 07:06 AM
max250
Aug 8, 2000 09:58 PM
