HARD STARTING
Old Dec 7, 2005 | 09:00 PM
insanez's Avatar
Default HARD STARTING
i have an 03 with 470 kit,edelbrock carb,trinity stage4 exaust,and all ignition upgrades.put a new battery in it and just will not start it i need to jump it from a car or with a charger.would putting a higher amp battery solve this problem?any suggestion would be great thanks,insaneZ
Old Dec 7, 2005 | 10:11 PM
thetank2006's Avatar
Too much compression and the starter cannot turn the motor over without a little extra power from the car/battery charger. Try getting a battery with more cold cranking amps and see what happens.
Old Dec 7, 2005 | 10:16 PM
insanez's Avatar
thaks will give that a shot
Old Dec 7, 2005 | 10:37 PM
BlackKawi400's Avatar
Also, check your grounds on the bike. I had the same problem and it was a really loose ground. Also, getting a battery with more cold cranking amps as said above, never hurts.
Also, you might check your fuse as well.
Old Dec 8, 2005 | 07:13 PM
quadbart's Avatar
Is there a decompression setup on the cam that maybe isnt working properly?
Old Dec 8, 2005 | 08:21 PM
insanez's Avatar
you know i thought that mabey the timing jumped but i will surelly check that out,thanks
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
