Lt230 needs a little engine help?????
Old Jan 1, 2006 | 07:17 PM
hondaguy1's Avatar
Default Lt230 needs a little engine help?????
I have a old lt230 somewhere in the late 80's. It idles fine, but mid range it backfires and topend it doesnt even reach. I have cleaned the carb and have tried all the adjustments. Also put a new cam chain in and still does the same thing. Im not sure whats wrong, if the cdi is bad or what. The compression is great, tested on a compression tester, adjusted valves. I dont know whats wrong.
Old Jan 5, 2006 | 08:38 PM
BigMc's Avatar
BigMc
Hey hondaguy1, Did you work out the problem with the lt230?
Old Jan 5, 2006 | 11:30 PM
hondaguy1's Avatar
no not yet
Old Jan 6, 2006 | 12:38 AM
BigMc's Avatar
BigMc
Have you tried running it with the air box lid off? Just to see what it would/might change?
Old Jan 6, 2006 | 05:54 PM
quadsport230rider's Avatar
try takin off the magnito cover and adjusting the points. i had a dirt bike that did the exact same thing and the points were not in the right positions
Old Jan 6, 2006 | 05:57 PM
hondaguy1's Avatar
I have tried takin the cover off and the filter out but didnt make a difference. What is the clearence supposed to be on the points? Thanks for the help every one
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Jul 30, 2015 09:39 AM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
